I am using ConceptStation version 10.00.16.84 to import some Geopak V10 files but any file I have tried to import using the OTHER option. I am getting the message below saying it was imported by with Warnings. Even though, it says it was successfully imported, there is not microstation lines imported to conceptstation.
Any recommendation?
Thank you
Are you attempting to import the GPK file, a Land XML file, ORD-type geometry, or plain DGN linework?
MaryB
just plan DGN linework.
issue resolved
I needed to assign coordinate system to the file I was trying to import.
Answer Verified By: Marcelo F. DaSilva
