I'm in the plans section of a project. Finally got all my views, and sheet views to synchronize accordingly with the default model. When I try to plot using the print organizer for batch plotting, some levels are not plotting at all. I have "saved setting" on all views and models and even re-uploaded the sheets in the print organizer. When I plot induvial sheets (CTRL+P) within the drawing, the levels do plot correctly.
How can I get all my levels to plot correctly in the print organizer?
Thank you.
That sounds almost as if there is some setting in your Print Organizer Print Style that is different from what you use when you print sheets individually. That does happen.
MaryB
Are you using level overrides?
Zane Pratt
Civil Designer
I have tried to replicate the Print Organizer Print Style by setting the plot driver and pen tables exactly as shown in individual printing, without any success. At this point individual printing would have taken less time than to try and figure out what is going on with my print styles.
It seems like level overrides is toggled off in both my scenarios (individual printing + print organizer).
Not sure if this will help. Doesn't work every time. Go into your named boundary file. Go to saved views. Update Saved View Settings for the sheet that is not printing correctly in Print Organizer. The Clip Volume will be blank after this process. Then select the correct Clip Volume once again. This seems to "resync" the Synchronize view from design model so the sheet models print correctly in Print Organizer.
