Hello, perhaps a silly question but visually I don't see in ORD vertical profile design a difference between design of vertical curves using either parabola or circular curves, no matter how much I create exaggeration. They should appear slightly different as K value does not define radius. Any ideas?
Many thanks
Oleg
Oleg,
It's mostly true that there are no visual differences. One of the differences isn't in what you can see, but in how they behave in combination with other elements.In theory you can design a vertical loop using a circular curve, but when you use a parabolic curve that will never happen.
I suggest you do an internet search for the differences and why a parabola is the preferred curve type.
Jan
Thanks Jan, even if both the circular and parabolic curves are symmetrical, there are fundamental differences between the two. But to make sure I have made a consultation with both online academia and Chat GPT Wolfram engine - they both concur with my premise of a small difference that should be obvious in vertical alignment design.
Took me a bit of time to confirm it but I think your assumption is not correct and differences between the two curves are significant, which I believe has a far reaching consequences... You can see image of comparison below. Happy to be corrected.
Which tool are you using to test? Profile Between Points shows a clear difference between the 2 curve types.
Mark
Same with the Curve from Element tool
Thanks for reply Mark - I use vertical alignment design tools in ORD, i set up approach and departing gradients and experiment with circular and parabolic curves (not asymmetrical)
If you zoom in closely, you will see there is a difference between them. Drawing a Microstation Arc I can see the circular curve graphics are correct. When the incoming and outgoing grades are the same and the crest is the same between the curves, you will only see very minor level differences between them.
Ok, let me try again
