I have a project where transitions between the templates are not going to the correct locations.
The blue lines are the preferred locations of the transitions.
Below are the templates being used.
The locations of the points are the design requirements for each template.
Do I need to edit each transition, removing the constraints for each point, and connect the points by hand?
SS2 (which is how these have been done in the past), the only thing was to have the same point names in the templates, which I have done in ORD, but without the same results.
Thanks in advance.
Shawn,
Thanks for the information. I guess i do not know enough about templates to do this correctly in ORD. I will need to learn quickly.
