Is there an option that allows the arrowheads on leaders to be filled in a profile annotation group?
I have annotations created for the vertical high/low points as seen below. We use filled arrowheads for all other dimensioning and want these to match. I'm not seeing anywhere to change these to filled. Is there something I'm missing or is this not an available option?
Many thanks in advance,
Matt
Matthew:
Could it be as simple as turning on "fill" in the view attributes for the drawing?
Best Regards,
Mark
I found the answer. The settings to set the fill are in the Element Template assigned to the leader. All that was needed was to "right click" and "add" a "fill type" to the "closed linear settings". Once this has been done within the DGNLIB I just needed to update the element templates in the alignment files.
Thanks again for replying Mark. I wouldn't have found the answer if I hadn't been thinking through my reply to you.
Answer Verified By: Matthew Whitley
