Item Types - Begin & End Station of a line from reference alignment
I'm hoping to utilize item types to be able to compute and create quantity tables for one of my projects in ORD.  I'm currently using ORD CE 2021 Release 2. I don't have much experience with item types and zero experience with expressions, but hoping to figure something out to speed things up.  Just as an example I was hoping to get an item type setup for a curb and gutter line that would provide the following information:
Reference Alignment - allow me to select the alignment that the curb and gutter is based on
Start Station - have ORD automatically get the end station of the line based on the referenced alignment
End Station - have ORD automatically get the end station of the line based on the referenced alignment
Side - which side of alignment
Length - I've figured this one out from other forums
The idea would be then to run this item type to a table for each alignment to use on quantity sheets. If anyone has any experience or ideas how to create the expressions to do this I'd greatly appreciate any input.
Parents Reply
  • This is one of the reasons we moved to a Linear Template workflow for edges as our standard workflow (Corridors only from pavement edge to pavement edge). Similar to gaps in pavement components from Display Rules, the only real way to be able to automate the extraction of data like start/end Stations is to model with them in mind and start and stop Template Drops accordingly.
    Mark
    OpenRoads Designer 2022 R3 (10.12)  |  Microstation 2023  |  ProjectWise CE 3.4
