In the older versions of Inroads it was possible to chose random multilabel features. From that generate a report where all reported XYZ of each features were in same chainages. I can not get this to work in ORD, either I get them reported in random intervals or I am not allowed to choose the features for report ?
What version of ORD are you using?
ORD 2022, release 3
That should be fine. In the OpenRoads Modeling workflow, Home tab, Reports -> Station Base Report, select your mainline then all of the offset features that you want data on. The Report Browser will open. On the left, under "StationOffset" (which should already be expanded), double click on "TransverseFeature.xsl". You should see a report with Sta\Off\Z\Y\X for all of your offset features at even stations along your mainline. Does this work?
Hi. That is exactly the process I have tried. By using the report "TransverseFeature" I get all the point generated at the line feature, and not by the intervall I would like pr. 10, 15 og 20 m? Is it because I don´t have the correct stylesheet Sta\Off\ZYX?
This may not be the official Bentley "we only do YouTube videos now" way, but I have experienced what you are describing and solved it by creating a new element using "Single Offset Partial". Zero offset, start at a clean station. Assign stationing to the new element that matches the original alignment. Run the Station Base Report using the new element. The stations reported by the Transverse Feature report should now be at the even interval that you specified.
