I'm using OpenRoads to annotate points of interest in a TCP motif file. I wanted to experiment with ways to expedite this process, so I created a series of Text Favorites in the Civil Labeler tool settings to call out recurring phenomena in the file. This approach worked well,and as the file in which I created the Text Favorites is one of several files requiring the same style of callouts, I'm wondering if there is a way for me to save the Text Favorites I created in this particlar file and export them to other files. Thanks
You need to create the text favorites in a dgnlib file. This file must be defined in the workspace by the MS_DGNLIBLIST variable. Then each text favorite will be available in any file you are in as long as you are using that worksapce.
Marc
