ORD Configuration
We are setting up ORD using our states configuration files.  The default location for the files is C:\IDOTCAD_ORD.  I would like to move these to our cloud (OneDrive) to share and manage for our company.  Below is a portion of the workspacesetup.cfg file.  Towards the end there is a line #  _USTN_WORKSETSROOT                        = $(MY_WORKSET_LOCATION)/.  It looks like I can uncomment and change this line to the OneDrive directory, is that correct?  I would like to use the same path for everyone, but OneDrive would require C:\user\username\OneDrive\...\IDOTCAD_ORD.  Is there a way around the user\username?
ORD 2021 R2 Update 10 v 10.10.21.04
# Civil Organization Standard Location
# Organization standards are base standards for a country or region or a
# large asset owner such as a DOT. These standards should be the base that
# provide most of the settings needed for OpenRoads Designer. Additional
# company specific and project specific standards can be layered onto the
# the Organizational standards using the WorkSpace and WorkSet respectively.
# By default Organization standards are located at
# \ProgramData\Bentley\OpenRoads Designer CE\Configuration\Organization-Civil\
# The default location can be changed using the MY_CIVIL_ORGANIZATION_ROOT variable.
# To redirect the entire configuration folder to a network location, uncomment the
# MY_CIVIL_ORGANIZATION_ROOT line and replace the network path with the appropriate network path.
# <<<< Make Changes Here >>>>
#MY_CIVIL_ORGANIZATION_ROOT = c:/Configuration/Organization-Civil/
%if defined (MY_CIVIL_ORGANIZATION_ROOT) && exists ($(MY_CIVIL_ORGANIZATION_ROOT))
CIVIL_ORGANIZATION_ROOT = $(MY_CIVIL_ORGANIZATION_ROOT)
%else
CIVIL_ORGANIZATION_ROOT = $(_USTN_CONFIGURATION)Organization-Civil/
%endif
# WorkSpace Standard Location
# WorkSpace standards are extensions or overlays to an Organization standard.
# A common use for WorkSpace standards is for company or client standards.
# Organization + WorkSpace + WorkSet = OpenRoads Designer Environment
# By default WorkSpace standards are located at
# \ProgramData\Bentley\OpenRoads Designer CE\Configuration\WorkSpaces\
# The default location can be changed using the _USTN_WORKSPACESROOT variable.
# To redirect just the WorkSpace folder to a network location, uncomment the
# following line and replace the network path with the appropriate network path.
#MY_WORKSPACES_LOCATION = c:/Configuration/workSpaces/
%if defined (MY_WORKSPACES_LOCATION) && exists ($(MY_WORKSPACES_LOCATION))
_USTN_WORKSPACESROOT = $(MY_WORKSPACES_LOCATION)
%endif
# WorkSet Standard Location
# WorkSet standards are extensions or overlays to a WorkSpace standard.
# A common use for WorkSet standards is for project specific standards and data.
# By default WorkSets are children of WorkSpaces and are stored in
# a sub folder of the WorkSpace. In other words, each WorkSpace has its
# own set of WorkSets. The default location is a sub folder named WorkSets. For example,
# \ProgramData\Bentley\OpenRoads Designer CE\Configuration\WorkSpaces\{workspace name}\WorkSets\
# If the WorkSpace is redirected to the network using the MY_WORKSPACES_LOCATION
# variable as described in the previous section, the WorkSet is automatically
# redirected to that same network location and no changes are needed in this section.
# If you choose to store the WorkSet in a different network location from
# the WorkSpace standards, this section should be used. When WorkSets are
# stored at a different network location than the WorkSpace, they are still
# a child of the WorkSpace and they must still be organized with parent folders
# named the same as the WorkSpace. These folders must be created manually.
# Optionally the WorkSets could be stored in a separate folder from the WorkSpace
# but be aware that this can cause users confusion because it is possible to create
# new files in a WorkSet (project) using incorrect WorkSpace standards. To use this
# optional method storing WorkSpaces and WorkSets in separate folders, uncomment the
# _USTN_WORKSETSROOT = $(MY_WORKSET_LOCATION)/ line below and deleted or commented
# out the line above it.
# To redirect to a network location, uncomment the MY_WORKSET_LOCATION line and
# replace the network path with your network path. This is the root path
# where the WorkSets are located and does not include the required
# WorkSpace folders that must be created manually.
#MY_WORKSET_LOCATION = //MyNetwork/MyWorkSpaces/
%if defined (MY_WORKSET_LOCATION) && exists ($(MY_WORKSET_LOCATION))
_USTN_WORKSETSROOT = $(MY_WORKSET_LOCATION)$(_USTN_WORKSPACENAME)/
%else
_USTN_WORKSETSROOT = $(_USTN_WORKSPACEROOT)WorkSets/
%endif
Parents Reply Children
