Paper size prints incorrectly
I am trying to print a layout in open roads. The paper size i have set is 36H X 52W. The scale is 50 and the dimension in cadd are 1800H X 2600W. I'm able to use the fence tool and follow prompts correctly in the print window but, when I go to print in a pdf viewing program. The paper size seems to max out at this number. Which I'm assuming is the max that the PDF program can handle.
    BLUEBEAM
Has anyone ran into an issue like this?
  • You can create custom paper sizes, not sure there is a max.  Do you have an example DGN with the border setup, what are your margins?  Where are you setting up the paper size, in a sheet model?  There are many ways to print. Sheet Models are one way but sound like you are using a Fence which is fine but probable need a few more details on you process to get the setup working as you want. Is 36x52 a custom size you use seems large.
    This is a setup to plot a 2600x1800in print area at 50 scale with a custom paper size of 52x36 with no margins defined.
    Mike Longstreet
    Vermont Agency of Transportation
    Civil Engineering Technical Support
    VTCAD Help
Reply
    Mike Longstreet
    VTCAD Help
