I am trying to create a horizontal report which is required at a particular interval. I almost got to this point(Images attached). Only issue is that I need only start and End Stations of an Alignment and does not require any other additional stations of the elements such as Tangents start & end, curve start& end, Spiral Start & End. Can someone suggest how to modify this code? Thanks in advance.
The geometry report includes the start and end station with all of the points at the user defined interval so there isn't any need to identify the first and last element in this case. See attached sample report.
HorizontalAlignmentIntervalOnlyXYZ.xsl
Hi, Thanks for the response, I know this report exists. I have taken a copy of it and modifying. But I have to create a custom report at a particular interval and only including start and end chainages.
I modified the above report from the original to produce the output you are seeking so I'd suggest to take a look at it
Answer Verified By: Rohith Dasari
Thank you so much. This is what I was expecting..
