Hello, I'm working with OpenRoads Modeling. I created an horizontal geometry, using NYSDOT workspace. When using Element Annotation, it doesn't show the PI STA info. Where to go to set this up?
Thank you,
Lucilia
You can start at this page and find some videos that may help you.
Drawing Production - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
There is a learning path as well
View Learning Path (bentley.com)
Step 5 is Annotation Setup
I still couldn't find the answer to my question on those videos. I used to work with InRoads and when select "View Geometry" and "View Stationing" there are options to select data info to display like PI's, PVC and PVT points.
Annotation is far more complex in ORD, so it's no longer as simple as selecting an option to include it. It's also no longer as simple as just creating a new ad hoc label style. Without watching the links, I suspect your answer IS in there. It's just a lot more involved than what we are used to.
If the NYSDOT alignment annotation isn't including a PI Sta., perhaps you could contact someone there. It may seem obvious, but I've run across items missing from DOT workspaces before. If they have a CAD Manual, it might be worth reviewing that - I know of a couple DOTs that include a section saying (essentially) "this doesn't work the way you expect, so here's how to make it function".
MaryB
