Adding Multiple Station Equations
I’m attempting to add multiple station equations to an alignment.  The first equation was added but when I attempt the second it does not add it.  I’m using the Geometry tab > Modify > Add Station Equation.
OpenRoads Designer CE 2021 R2 v10.10.21.04
Parents Reply Children
  • I saw the A & B designators as you listed above.  However, when I added these to the station equation the stationing turned to 0+00.  I was able to add multiple station equations by either selecting the point or typing in the back station, selecting the check box to lock the back station, then entering the ahead station.  For some reason entering the back station and using the tab key to lock the station was not creating the station equation(?).  My entries were like this 399+14.06 for BK and 398+86.83 for AH.  No designators added to any of the station equations.
    Thank you for taking to time to respond.
