Is it possible to make cut slope follows the carriageway transition
Hi, I have drop a wide carriageway template with cut slope in part of a corridor. I would like to add a transition to another template with narrow carriageway. However, after I create transition, I cannot edit the cut slope constraint in "edit transition", and the cut slope don't follow the transition.
Does anyone have this problem too? Much appreciate if there is a solution.
Parents Reply
  • I am aware of the End Condition Exceptions. That's the parametric approach I use. What we don't have is the function of the actual transition editor, where you can manually connect one point to the other. I know more than a few people who have gotten confused (yes, since InRoads) that the tool to define the transition of part of the template can't be used for the entire template. I wish we had THAT capability for end conditions as well as backbones - as in, I wish we could do it all from one location with one tool.
    ETA: I think this confusion is what OP is posting about. The Edit Transition tool doesn't include the end conditions.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
