Is it possible to make cut slope follows the carriageway transition
Hi, I have drop a wide carriageway template with cut slope in part of a corridor. I would like to add a transition to another template with narrow carriageway. However, after I create transition, I cannot edit the cut slope constraint in "edit transition", and the cut slope don't follow the transition.
Does anyone have this problem too? Much appreciate if there is a solution.
