Profile sheets showing zero levels
My profile sheets are showing zero levels on the existing surface annotation box.
Everything appears fine in the annotation group. The terrain surface is active and showing in the sections. Have tried a number of different annotation types
Have wasted hours trying to sort this out. Has anyone else come across this hurdle and found a solution?
Using ORD CE 2022 Release 3
Thanks in advance, Mick
Parents Reply Children
  • Hi Mick,
    Thanks for sharing the solution here.
    However, I am a bit confused how you got the terrain displayed as shown on your 1st screenshot, if it was not made active in the geometry file. From testing in ORD 2022R1 if a terrain is attached and made active in a drawing file (where the long section drawing and sheet models are created), the terrain is not shown unless it is active in the geometry file (where the vertical alignment is created).
    Mariusz
    OpenRoads Designer 2022 R1
