Hey,I am currently doing some stop sight visibility on a bike path bridge in open roads. The problem is that there are barriers applied on the sides which will affect the sight, but it seems that open roads is seeing through the barriers. Does anyone have a solution to this problem?Kind regards.
At the prompt "Locate Corridor or Alignment", if a corridor is selected then the barriers would need to be part of that corridor to be considered. If an alignment is selected then at the later prompt "Locate Design Surface" the barriers would need to be included in that terrain to be considered for visibility.
