Is there a way to grab / highlight all the text that have the same properties. so I can do a scale change all at the same time? I have all this text that is on the same level and I'd like to grab the all the "Lot 1" style texts at once to modify them instead of one at a time individually or clicking each individually and holding ctrl.
This text was copied from inroads and now I have to modify the scale for plats. I've adjusted features and levels to ORD but going through each text individually takes awhile especially on bigger projects. Could there be a way to import text from inroads and keep its scale from inroads?
Once you select all the text, you can either use the Scale Element tool using the "About Center" option to apply a single scale factor, or you can use the Change Text Attributes tool to assign a new text size to everything selected.
MaryB
