Survey Cells rotate when you rotate the view
In drawings with ORD generated survey points, signs for instance, we rotate the cell to the same orientation as the sign in the field. The problem is when our client rotates the view to match their sheets all of the signs look as if they were rotated a different direction. If you return to top view, they appear correct again. These drawings were created using the TxDOT workspace in OpenRoads Designer CE - 2021 Release 2 Update 10 Version 10.10.21.04. I know its not the current version but it is the version specified in the TxDOT standards.
