How do I apply cross section annotations to only a specific corridor?
I have multiple corridor models referenced into my cross section sheets, but I only want to annotate one particular corridor model. When I run the Drawing Model Annotation tool, my annotation group is annotating other corridors that I don't want labeled. How do I tell ORD which corridors to annotate and which corridors to not annotate? I remember being able to do this in SS10.
Version 10.10.21.01 2021 Release 2 Update 10
Parents Reply
  • Yes, agree.  We often have multiple corridors that would appear in cross sections that would and should not be annotated.  Often when cutting cross sections on one specific road a sideline road will show in the cross sections and the slope annotations would be very misleading due to the skew that perpendicular cross sections on a mainline might lay on a sideline. These could be at awkward angle making the annotations somewhat odd and not helpful.
    This is also true when we use corridor models to create channels under bridges.  The annotation of channel slopes from a roadway cross section could be totally random angles.  We would typically want Channel cross slopes annotated in Channel cross sections but not in roadway cross sections and Road cross slopes annotated in roadway cross sections but not in channel cross sections.
    Mike Longstreet
    Vermont Agency of Transportation
    Civil Engineering Technical Support
    VTCAD Help
