removal of Duplicate feature definitions / symbology / element template etc in ORD
I'm attempting to set up a 'clean' set of DGNlibs harvested from different sources, but am experiencing multiple duplications of Features definitions / symbology / element templates etc. Is there a tool that can assist with identifying and 'cleaning'/ deleting these duplicates?
  • Hi Steve,
    Unfortunately not. We really need some kind of Civil "Compress" tool to clean up unused Civil Data in dgn files. Perhaps post an idea to the Civil Ideas site?
    Mark
    OpenRoads Designer 2022 R3 (10.12)  |  Microstation 2023.1  |  ProjectWise CE 3.4
  • What version of ORD are you using? I’m not sure if the ability to import and export features and symbologies is still supported in the newest versions, but there are Migration Utilities that can be downloaded and in the readme files with these tools, it explains special instructions for a configuration variable that when defined enables export and import as XML of features and symbologies. These files can then be converted to Excel files for manipulation and then converted back into XML.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
