I tried to install Office 365 64 bit version. After that I was receiving an error about some Visual Basic issue not found. I since have uninstalled Office 365 and installed the 32 bit version that was on my machine before. The Visual Basic error has stopped but I am not able to load my feature definitions for the survey. The cells are replaced with yellow triangles with !. I have tried to repair the PowerSurvey 08.11.09.878 without luck. Before I uninstall PowerSurvey I want to ask if there is something else I am missing.
Dan
Here is the forum to go to for Civil products: OpenRoads | OpenSite Forum
I belive you can Move your post over there with the "More" option.
MaryB
