Import/Export Label Definitions ORD 10.12
I know you can import label definitions from an XML file by enabling the _CIVIL_STANDARDS_IMPORTEXPORT = 1 variable
But, is there a way in 10.12 to export label definitions created in one file to an XML file and then import those to a dgnlib?  It doesn't seem like there is a way to do this....but there should be.
Marc
