Hello Everyone, How can I avoid kink in order to get rid of the error 'Non-collinear' while constructing clothoid between a line and an arc?
Thank you in advance.
Best Regards,Divya
Obviously your transition (chlotoid) should have R=infinity (0 curvature) at line and R=Rarc (curvature 1/Rarc) at arc, where Rarc is the radius of arc.
Thank you for your reply.
I have tried constructing the clothoid with 'Multiple Element Regression Analysis',keeping the length free. But the clothoid is not closed on the arc side which is why I manually edited the direction of clothoid in order to make sure it closes on both sides with an angle 180 degrees, and I ended up getting this error 'non collinear'. Is there anything that I am missing while constructing a clothoid?
Best Regards,
Divya
Can you please post a screenshot of what you are trying to achieve?
What type of project it is? Highway/Rail?
New, rehabilitation?
There is only one transition, from which we pick an arc which we scale with a parameter.
For a chlotoid to transition between 2 elements with a given parameter you need a certain offset, otherwise you will end with your situation.
Val.
