I have enabled Paper size editing when I'm plotting to PDF. As you can see, I selected a standard plot driver size 24 x 36. I'm trying to edit the paper sizing to reflect the actual drawing size (24 x 25) - scale 300 - see below of image. I manually type in 25 to replace the 36 and it doesn't allow me to edit paper size at all. This tool used to work and come in handy, but I can't edit the paper sizing anymore, what could be the issue?
I don't want to have all that extra white space on a 24x26 PDF.
Thank you,
A bit of a long shot, but you may not have the right permissions to edit the sheetsizes.def file in your workspace.
