I was wondering if anyone has had this problem: I have the GEOM file (which contains the mainline and sideroads alignments) referenced into my working file, when I open the profile view for the mainline alignment I can see the profile (first picture), however, when opening the profile view for a sideroad, I get a blank view with nothing in it (see second picture). The terrain is active, levels are all on.. Not sure what is causing this. Does anyone know?
Hi Natalia, are you using Projectwise?
I know there is a bug opening Corridor Features and having their profile space blank. Is the side road geometry you are trying to open also Alignment Geometry or a Corridor feature?
Mark
Hi Mark... is there any update on this? I have the same issue Natalia does. In my case, I am using ProjectWise (453 build) and ORD 10.12 (2022R3). I'm trying to copy a vertical alignment from one DGN to another. I have a vertical alignment I need to update in DGN1, and the revised one in a working DGN2 (which has the same horizontal alignment, as it was created from a saveas of DGN1). I'm trying to use the Copy Vertical command, so I display both profile views. the "live, older profile that i will eventually replace shows up. the referenced profile does not:I've checked the levels for both views. Both files have only one profile, and it is active in each file. But I can't copy a profile I can't select. This seems to be something of a weakness in this command; if one *must* copy from a view and can't see the desired graphic in that view... well, crud. I will have to find a workaround (I am thinking XML?). Can the Copy Vertical Command be updated so one can select a vertical from Explorer. Or even better, allow copy paste from referenced alignment data to the current one that's open live? Any info you might have is appreciated... thanks!
