How does ORD decide which levels to print?
I finally got my design model, drawing models, and sheet models set up so that the levels displayed in the design model trickle down to the sheet models. For example, "LEVEL A", which I want to be OFF, is OFF within all models. However, when I print the sheet model, LEVEL A shows up on the PDF. Clearly, ORD is not using the level ON/OFF display from any of these three models for the plot. So, my question is, how does ORD decide which levels to print? Where is that controlled?
