Try the Surface> Design Surface> Drape Surface with Tools> Locks> Locate set to Graphics. At the top of the Drape Surface dialog, the Current Locate Mode should display Graphics if the lock is set correctly. Click the Help button on the dialog for more information. I hope this helps!
By the way, you posted in the correct forum.
Jason Smithey
