Power Civil: Dynamic slope tags wrong
I applied dynamic slopes to the object named "12th North-Opt_1 in the attached GSF. I want to edit the locations of the slope transitions in the area shown in View 1 when the DGN is opened. When I perform a slope query, the values do not correspond with the slope tag locations. The query values match the model but the tag locations do not, so it appears the tag locations are not showing correctly. The behavior occurs throught the object.
Can someone check on this please?
12th St.zip
