InRoads Drainage Profile Questions
Hi--
I've been nessing around with displaying our drainage profiles via InRoads v08.09.02.16.  I did an Annotate Drainage Profile, and a Place Profile Note to see how much of the InRoads text we can use with the least amount of rework.  When annotating I get an offset of 18', which is correct.  The drainage is 18' off the road alingment.  My Problem is, while using the Place Profile Note, I either get an offset of 0.00 or it says {OFFSET}.  I would like to use the Profile Note since there are more options to get it to display to our standards.
Attached is a picture showing that is just says {OFFSET}, in green. The white is the annotation.
Also, here are the commands I am telling the Place Note:
GRATE INLET TYPE 2
{Delimiter}
{ALIGNMENT_NAME} {STATION} ({OFFSET} LT)
RIM {Elevation}
How can I get the {OFFSET} to work?  Thanks.
Parents Reply Children
