When loading contours from a TIN using "Load DTM Features" in GeoPak, the contour lines are not smooth and straight. The contoured area can be a steady/constant slope with constant elevation at top of slopw and constant elevation at toe of slope and the contours will not be smooth and/or straight. Is there a way to improve the "stroking" (?) of the lines/curves to create a "smoother" contour line?
I'm using breaks and spots when creating the DAT file and I have experimented with the "stroking" settings (Curve Tolerance & Min Linear Distance) with minimal success. Perhaps I'm expecting too much but I've seen other files with perfect line segments and arcs for contours (don't know the creator of the files).
Is there another method of generating/loading contours with GeoPak?
did you try drawing the contours with B-Spline smoothing enabled?
Its a smoothing option on the Load Features>Contours dialog.
It may help...
Hi David,
can you post some sample data - so we can take a look?
Neil Wilson (aka Neilw)
Power Civil v8i 08.11.07.245
AutoCAD Civil 3D 2018
