Display features in Inroads 08.08.02.16
When I display my features they always come on with 'level override on',
i.e. co=0, ls=0 and wt=0. My 'default' level has no overrides defined, so I
wonder what is causing that?
Is there a way to prevent this, a toggle? Something in the stylemanager?
Jean Castro
  • Here is how I got mine to display in different weights and colors:
    Tools > Feature Style Manager
    I double click on the feature that I want then when the "Edit Feature Style" window pops up I hit the "edit" button in the symbology table. I then edit the correct "Use." You probably want to edit the Plan Line. Be sure that after you change it you hit "apply" instead of just x-ing out. Hope this helps.
    Jason
Reply
    Jason
