point data to surveyors
I'm using InRoads XM V08.09.01.45 with AutoCad 2008, and I would like to identify points within a drawing and export them to an ASCII file (pt#,N,E,Elev,Desc) to be up loaded by the surveyor.  I would like to maintain and protect the point files generated.  Is there a simple way to do this?
  • Have you used Tools>XML Reports before? There are reports for both geometry and surface that will work.
    Is your data in a surface or a geometry project?
    If your data is in a surface you might also try File>Export >Surface.
    You have options but to give you a specific answer requires knowing what you're starting with and what you want to end up with.
