InRoads Suite V8i- Drainage Preferences files
Bentley InRoads Suite V8i - I am trying to load  two files into Inroads. I am trying to find a Generic file to link to my Set Project Defaults.  The two file names are "Drainage Structures (*.dat)" and" Rainfall Data (*.idf)".  Any information about these two Preference files would be appreciated.
Parents Reply Children
  • Is there a configuration variable that once set can point all users of a site to the same *.dat file ?  Currently everyone has got the files on their C:\ Drive.  thanks
  • You can setup a Project in the Project Defaults and that Project can point to hard coded paths, configuration variables or combinations of the two.
    You can also export the settings in this dialog box for import into another user.
    I have one main project that uses almost only configuration variables and when my users select a project in the MicroStation Manager, it defines those variables and InRoads loads different files for different clients.
    The only item that must use a normal path is the XML reports folder.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • Hi
    I never realized or tested that "Project Defaults" supports configuration variables!
    Thanks!
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
