Storm and sanitary - Utilities stord elevation problem
Hey there,
 I m starting working with storm and sanitary and i m trying to create utilities with a coverage of 0,85m to represent the district heating.
The elevation which should be stored is the the top of the utility so my coverage is always the same and i dont have to calculate it for each utility. I tried to create 3 utilities along each other and change the "stored elevation" option each time : top, center and bottom, unfortunatly nothing seems to happen. The 3 utility lines are displayed at the same elevation, the elevation is also the same in the database and when i display them as solids every solid is created above the utility line instead of above centered and under the line.
Has anyone ever experienced that problem? Any idea which could help is welcome.
 Hope my post is understandable enough.
 In advance thanks
Alex
Parents Reply Children
