Power Civil: Merge multiple TIN's
I have several TIN files that I want to merge into a single TIN. Is there a way to do them all at once or append each one to the master surface? As I see it, I will have to merge surface 1 and surface 2 into surface1-2, then the resulting surface 1-2 plus surface 3 into surface 1-2-3, and so on. It gets pretty messy when there are 6 surfaces to be merged.
 Power Civil v8i
Parents Reply Children
  • The TIN's are built from DAT files which were extracted from DEM files . I thought about loading the triangles from all the TIN's and extracting them as graphics into a new surface but that approach doesn't clean up the edges where the TIN's overlap.
    In any case I was not able to merge the TIN's due to some error during the process. These are 10 meter DEM's so the TIN's are quite large and I am probably just running out of memory. I may have to keep them seperate for now.
    Neil Wilson (aka Neilw)
    Power Civil v8i 08.11.07.245
    AutoCAD Civil 3D 2018
