Corridor Modeler: DTM vs. TIN. Why are they different?
I am working with Corridor Modeler and I have imported a GEOPAK tin file. I had Corridor Modeler draw cross-sections showing existing ground both with the tin and with the dtm. They dont match. This is a problem. My proposed model has a template that ties into the existing ground at an offset defined by a plan graphic which represents the ditch bottom. However, the dtm failed to accurately pick up the ditch flow line on the right side. See Sta. 334+40 for example. The red line is the tin, and the blue-green line is the dtm.
How can I fix this?
Josh Mauritz
MS v08.11.05.17
GPK v08.11.05.39
