Hello all,
I have received huge data in contours format (1m interval & each CAD file 200MB to 400 MB total 12nos) from client and the total area covers around 12313.9 hectares. They don't have other format and it is totally hilly terrain. Each time I upload CAD file model file size increase around 400MB to 700MB. I was compressed model file after each CAD file upload. After uploading 5 files Mx was not responding and Model file crashed. I have tried several times. Can you please suggest me any other way without losing data?
MX XM version
Sri
Good Day:
I am not an MX expert so I will need to rely on one of my colleagues to provide you with pointers to the exact MX tools. But in general terms, one of the challenges of producing a surface from contours is that the vertices on the contours might be very dense which results in a very high number of points in your target surface. You can often filter these vertices by as much as 90% and not have a significant effect on your surface.
If there are tools in MX to allow you to filter the contour vertices before you extract them into a surface would be beneficial to your workflow.
Alternatively, if you have access to Bentley Map there are some nifty tools in there for filtering the vertices of a linear element. It can take an entire selection set of your contours and apply a filter and dramitcally reduce the number of vertices. Then when you import to a surface it will have lots fewer points with a corresponding reduction in file size.
Robert GarrettSenior Product EngineerBentley Systems Inc.
Sri,
You can use an optimising tolerance in MX to reduce the amount of points on strings.
Once you have imported each file, use the File > Export > GENIO > Models to File option, and select the model that has just been imported. Then open the file you have just created in a text editor.
You will see a line starting with "080" - one for each contour string. You can edit these lines to introduce an optimising tolerance. You need to set field 3 to HORZ, and field 10 to the tolerance you need.
So for example this:
080,0001,4= 125.000, 0.0, 0.0, 7702
Becomes this:
080,0001,3=HORZ,4= 125.000, 0.0, 0.0, 7702,10=0.5
You will need to adjust every 080 record, which you can do using Find and Replace functionality in most text editors. The value in field 10 is key to this technique, and a little trial and error will be needed here to find the best tolerance to use.
I would report the number of points in the original model, edit the text file for every 080 record, then use the File > Import > ASCII File option to read the GENIO file back in. Finally, report the number of points in the new model. Obviously there is a tradeoff here between the reduction in the number of points and the accuracy of the edited data. You could also change the model name in the text file to note the tolerance you used, so this:
DELETE CONTOURS CREATE CONTOURS
DELETE CONTOURS USING POINT 5 CREATE CONTOURS USING POINT 5
You will need to remove the three spaces at the start of these two lines for MX to read them (three spaces means that they are commented out). MX model names are alphanumeric only.
For more information on the optimising tolerance, look at the help topic "Linemode Reference: GENIO: 080 General input of strings".
Jon
Jonathan's Smith's recommendation is good, but may not solve the problem of sheer volume. If not, read on ...
If as you say the client really does not have and cannot obtain the base survey model from which the contours were generated then the client must accept the risk (which may be very slight to significant, depending on how the contours were generated) of significant errors: contours are of course of a tertiary order of accuracy. That established, lets move on to how to deal with this.
Firstly, I would ask what form the data has been supplied in: you mention CAD file upload, so my guess is that you have DWGs or DXFs and are loading through the MX File > Import > ASCII data menu, which converts a DXF to a Genio file. (I would certainly not recommend importing such a huge amount of data via interactive MX -> CAD conversion tools).
What I would suggest is that you run the process with the automatic running of the genio data turned off: this means the initial output is just the genio data. Assuming that it is just contours in the dwg and nothing else, you should convert to the dummy model names BLOCKED and UNBLOCKED. Make a back-up copy of the genio file. Open the file (you will need a good text editor), and look to see if there is any instance of the modelname 'Blocked'. If so delete every chunk of data from (and including) that genio line to the next 999. Clear them all out. But there may not be any.
Next look for and count up the genio lines with the 'Unblocked' model name. Is there more than one? If so, this gives an opportunity to divide the file up into several smaller file - potentially one for each Genio session. However it may well be that there is now only one genio major option line, up at the top. Let's assume so, as this is the worst case and we can look at how to deal with that.
Each of the new files should start like this
GENIO,UNBLOCKED 017,NORM 001FORMAT(2D23.17) 003,ORDR,4=1,1,2,
Then will follow string/point data, each of which commences will start and end something like this (the number of intervening datalines will depend on the number of points in that particular string - each line is a single point)
080,0002,4= 36.500, 0.0, 0.0, 7702 ... 0.00000000000000000D+000.00000000000000000D+00
You can now transfer/copy from the 'complete' genio data into the series of smaller files you have prepared long chunks of string data, so that the files have an broadly similar size (your text editor will show line numbers, and you can use this to plan this work). Each individual file should end as follows:
999 finish
Now if you consider each of these X number files as children, it needs a parent (you can decide for yourself whether it is mum or dad!) This is the input file you will actually run. Give all the children the file extension .CRD Give the parent file the extension .INP This will help clarify the structure, and indeed the filenames themselves could emphasise this. Content of the parent file is as follows:
MX output subsys sysdel,dbug.prn 999 output,dbug
delete,unblocked create,unblocked
input,[child filename 1] input,[child filename 2] input,[child filename 3] ... as required delete,[name for your contour model] rename,unblocked,[name for your contour model] compress,modelfile output subsys sysdel,dbug.prn 999 You could insert here input code to do any necessary editing, eg reducing model to area of interest, correcting errors etc.
finish
Make sure there are no other major option lines mentioned than those I've specified above.
Okay, that's done! Now you can get on with the job itself. 'twas ever thus!
Jonathan Bridge
