MX XM Users
Any MX Guys or Girls found their way on to here yet?
 Would be good to get talking....
 MarkDJ
  • [Cross posting] Original message as posted on discussions.bentley.com
    advice on how do you deal with customizing Microstation's Workspaces etc would be appreciated
    The background of the problem: MS uses Workspaces as a main customization template, the default settings "out of the box" have automatic saving upon exit enabled and enter into untitled drawing enabled
    Whats wrong with that?
    Nothing wrong as long as you use only MX, but if you want take advantage of the Power Draft then the problems begin as for my personal preferences this settings are better left off disabled) After changing these settings to my proffered in Draft then MX is affected by additional clicks to cancel saving the default seed file. I am not a MS newbie -have had several years of experience but last I touched MS was more than 7 years ago. In the meantime things have developed a lot. Does any one here have some experience on how to tweak MS workspace in order to have two separate workspace settings (namely XM and Draft) which will not interfere with each other?
Reply
