I'm currently developing a program with VB6 using the MX SDK. Thr program is required to perform a lot of normal calculations from points onto a master string.
I am using the 'MFWPSMcNormal' method from the MFWSystemBuild object to do the normal calcs (i.e. obtaining chainages on a master string from a point). When I compile the .exe the program works perfectly from my PC.
When I try to run it from another PC, the MFWPSMcNormal method does not appear to work. On testing I found that the lReturn value was returning -1 (i.e. an error), whereas on my computer the lReturn value was 1 (successful normal)
The testing was done using an identical string model on both machines and I've ensured the MossSysBuild.dll is in the correct location on the other PC.
Does anybody have an idea as to what I am doing wrong?
Thanks in advance
AM
Thanks Phil, thats very handy
I have also rewritten the normal code to use the MX 996 options, but used the MFWGetData option to read from the temporary data file. The good thing is that it works on other computers, downside is that it takes a lot longer to process. I'll try to plug your code in and see if I can get a quicker result.
