In InRoads 8.11.5.47 the "Radius + A" are incorrectly displayed as you can see in the attached PDF.
R900 should be on the left side of the leader line segment amd A275 on the right side and so on.
Is there an option somewere, that I have missed ?
Ólafur
Ólafur,
I filed D-58889 for this. I apologize for the inconvenience.
Jason Smithey
All but one of the issues were problems in the XIN file. There was one issue in which the constants were overlapping when there was an SS with an unequal constant transition. This has been marked as fixed for the next major release. In the attached XIN file, use the WORKS CORRECTLY preference.
Thank you very much for your help.
The solution was to find the right combination of "+and -", "100/300 degrees" and "left center / right center".
"Next major release" for the overlapping fix. Is that weeks, months or a year?
