CR - MX Colortable
Is it possible to synchronize the MX colortable with the Microstation/Powerdraft/AutoCAD colortable? If I change the colortable in my DGN to a AutoCAD colortable, it doesn't change the colortable from which you can select colors (CL0001). Also the colornumbers used in an inputfile are being changed to other colornumbers in PowerDraft. This is very anoying when making an isopachyte colorplan.
 With regards,
Gunther Groenestein
Parents Reply Children
