When I try to load the new InRoads, I get an error about my microstation 8.11.07.171 can't be found, but I have the right version loaded as seen by this screen shot.
Ray
i cannot find this update( ms081107180en_updt1.exe). Do you recall where you found it?
Robert
When I run the update file, I receive the following error message:
Microstation V8i SELECTseries1 is installed in C:\Program Files\Bentley\Ms0811s1\Microstation
Any idea of what's wrong?
Christophe,
Is the language of your MicroStation something other than English? The update is currently just for English. Translated versions should come later.
If your MicroStation is English, try running a repair on it before running the update.
Jason Smithey
Thanks!
Microstation is in English. It now seems to be a company installation related problem. Nobody at our company seems to be able to install the patch. I think I just have to wait for somebody to fix the problem!
Hi Christophe,
Many thanks to you and those at your company that helped us troubleshoot this.
Just to let everyone else know what the issue was...
We found that the MicroStation Update Patch (08.11.07.180) will not install if MicroStation V8i SS1 (08.11.07.171) was installed using the "EasyMultiInstall.vbs".
We were able to work around the problem by uninstalling MicroStation, and re-installing it using the "MicroStation.msi".
Thanks agian, Kevin
hey its really so great think i think you have excellent thought which is so smart . i want to apperciate.
adam
http://www.pokertime.eu/10ongoat
