When I try to load the new InRoads, I get an error about my microstation 8.11.07.171 can't be found, but I have the right version loaded as seen by this screen shot.
Ray
Is this update only there for Inroads? Or is there other benefits to applying this update outside of Inroads? I had gotten wind that the update should help with the speed of Microstation on Windows 7 machines. If this is the case then will it be more "accessible" to the users who do not use inroads? I was just thinking it might make it easier to find.
Thanks for helping,
Robert
Robert,
MicroStation V8i (SELECTseries 1) Update 1 is not a complete version. It is not listed under Enhancements and Updates because it was created specifically for a particular set of products. If you click on its link in SELECTservices, the description lists the products for which this Update was created.
The Update is mentioned three times in the readme. It is mentioned in the last sentence under Requirements> Installation Requirements> Software Prerequisites. It is also mentioned in the Known Issues and under Installer Notes in the Readme link.
Jason Smithey
When I run the update file, I receive the following error message:
Microstation V8i SELECTseries1 is installed in C:\Program Files\Bentley\Ms0811s1\Microstation
Any idea of what's wrong?
Christophe,
Is the language of your MicroStation something other than English? The update is currently just for English. Translated versions should come later.
If your MicroStation is English, try running a repair on it before running the update.
Thanks!
Microstation is in English. It now seems to be a company installation related problem. Nobody at our company seems to be able to install the patch. I think I just have to wait for somebody to fix the problem!
