hi,
when can we expect inroads working under vista x64? for microstation its not a problem
but without inroads its worthless.
best regards,
marcin
Hi Marcin,
InRoads has supported 64 bit OS since the release of InRoads XM SP2. So any version after V08.09.02.16 should work.
Thanks, Kevin
Steven,
InRoads on AutoCAD in a 64 bit operating system is not supported. This is noted in both the Requirements and Known Issues of the readme. I apologize for any inconvenience.
Jason Smithey
Thanks for the quick reply. I am just doing some testing to see what new systems our office can purchase.
Steve
Jason,
I jsut tried running inroads and autocad on windows 7 32 bit today and it is freezing on the startup the same way as it was with the 64 bit OS. Do you have any suggestions. On a side note, I know that it should run on windows 7 32 bit because the instructor for an inroads course last week was running autocad and inroads on this type of setup. Any ideas?
