How can I remove the Applications that I am not licensed to use from the microststion Applications menu,
prior to this version I could control this with my own custon applications menu via a DGNLIB.
I do not want our users to activate products that we are not Licensed for, having them in this menu is not a good idea.
Just a fyi ... we had a Bently Map usage reported on the SelectServer as well.
Anna
If you start from the InRoads executable and then activate Map, then it should not use an extra license. There are a couple known issues in which an extra license is used. One is when you start MicroStation, MDL Load InRoads, and then try to activate Map. Another is if you start InRoads for example, exit its explorer, start InRoads Suite, and then try to activate Map.
Jason Smithey
