Inroads v8i with Microstation v8i SS1
Is there a way to export an Inroads RWK project from projectwise rather than going to each file to perform the export?
Marc
Marc,
I am not totally sure that I understand your question. If I am interpreting you correctly, the only way (that I am can think of right now) to export the project and the files denoted within it all at the same time is to:
I hope this helps.
Jason Smithey
