Using: Geopak Version is 8.11.07.227 (Select Series 1) Microstation version is 8.11.07.10 (Select Series 1) Windows XP
When I open the Corridor Modeling tool, I can first import my geometry (chains and profiles) but when I go to import the plan graphics nothing happens...they wont show up in the ALG Viewer window.
Likewise, if I start a new file, and first import my plan graphics (from the same dgn file) I then cannot import my chains and profiles.
If I import my geometry, change my profile, I cannot re-import the profile for it to re-read the updated information. It seems like it will create the alg file for the first import operation, however, no subsequent operations will get imported or updated.
Any suggestions?
I've never heard of anything like that. Can you post your data?
Derricke
To start off we use ProjectWise V8i...
So, I was creating working copies to post and exportig the data outside of ProjectWise (we keep our Geopak data outside of ProjectWise on a shared network drive). For giggles, I wanted to try and import the data without being inside of ProjectWise and outside our normal site configuration blocks...and presto it worked!
I'll try a few other things but I don't know if you by chance might know of any v8 2004 configuration variables that could be causing a hickup, as I'm using a workspace that was originally set up for 2004.
