I am working with Bentley Geopak Microstation/Civil V8i. I am currently working on a project with significant utilities at an intersection. a couple of the utilities I am responsible for design of (water main, Force main). Several others are utilities to be relocated by individual utility companies however, I am responsible for verifying we should not have conflicts.
I have my design roadway and storm sewer in a 3D model. Is there any way to import the various utilties into this 3D model to be able to view all the utilities and check for possible conflict points? Given an alignment and profile as well as a diameter, one would think I should be able to import this into the 3D drawing.
The only information I can find is to use the Conflict Finder in the Drainage module. However, this does not give me a 3D rendering of the utilities.
Thanks for any help.
Ryan
Ryan - Instead of creating miscellaneous utilities, create these existing utilities as water lines. For example, let's say you have an existing underground telephone line.
Robert GarrettSenior Product EngineerBentley Systems Inc.
