Cannot reduce a Leica DBX file (PowerCivil GEOPAK)
PowerCivil V8i Select Series 1 V 08.11.07.229
Tried to create a new dataset using a Leica DBX file as the data source (see image 1) and get the following error (see image 2);
"This application has failed to start because DataBase1200_VCB.dll was not found. Re-installing the application may fix this problem."
I first encountered this error in V 08.11.07.227, so I checked in the forums and noticed that this new update was available, so removed 08.11.07.227 and installed 08.11.08.229 - error still exists.
Parents Reply Children
